Products
Henkel’s Brush-Top Packaging Simplifies Application of Lubricants
Melissa Larson | August 12, 2015
For precise, one-hand dispensing of Loctite anti-seize lubricants, Henkel Corp. has introduced a compact new package that features an easy-to-use Brush-Top applicator. Sized to facilitate hand application, the 7 oz. Brush-Top tube is currently available on four Loctite anti-seize formulations: Copper-Based, Silver Grade, Heavy Duty and Marine Grade. Easy to take on the go, Loctite Brush-Top anti-seize lubricants are suitable for touch-ups and equipment maintenance.
Designed for use in severe industrial environments, anti-seize compounds protect metal parts from rust, corrosion, galling and seizing. These lubricants ease assembly and disassembly of slip-fit and threaded joints, reduce friction and wear on critical operating equipment, and protect against high temperatures, heavy loads, chemicals and fluids.
Melissa Larson
