Larson Electronics Reveals 150 W Portable Explosion Proof LED Light
Melissa Larson | August 12, 2015
Larson Electronics has announced the release of a Class 1 & 2 Division 1 & 2 portable explosion proof LED light mounted on a base stand fabricated from non-sparking aluminum.
The EPL-16BS-1X150LED-X24I-50 portable explosion proof LED light from Larson Electronics provides operators an easy to maneuver LED work light for use within hazardous locations. This portable fixture is comprised of a 150 W LED light head that is mounted atop a base stand fabricated from non-sparking aluminum, and operates on 120-277 V AC stepped down to 24 V DC via an inline transformer. The LED light head produces a brilliant flood pattern of light that is ideal for illuminating enclosed areas and hazardous locations where flammable vapors, gases and dusts may be present.
The LED lamp head is T5 temperature rated and retains 80% of its lumen output after 60,000 hours of use. The lamp can be easily adjusted up or down 90 deg. and locked into position by loosening the two hand screws located on the side of the light head. Once the light is in the desired position, the operator then tightens the screws back to set the position.
