Products
Photron Debuts Rugged, Compact High-Speed Camera System
Melissa Larson | September 9, 2015
Photron, Inc., a global leader and manufacturer of high-speed cameras and image analysis software, introduces the FASTCAM Mini AX100, a high-speed camera with unparalleled light sensitivity and low noise performance. High-G, compact, and only 120 mm (4.7 in.) H x 120 mm (4.7 in.) W x 94 mm (3.7 in.) D in size, the affordable Mini AX100 provides 1,024 x 1,024 pixel resolution at up to 4,000 frames/sec. (fps) and 540,000 fps at reduced resolution, making it the fastest, most light sensitive high speed imager available.
The lightweight, 1.6 kg (3.5 lbs.), one-piece camera joins the recently introduced FASTCAM Mini AX50 to deliver high frame rates with excellent image quality and 4GB, 8GB, and/or 16 GB memory options. Applications include on-board and off-board automotive safety testing, defense/aerospace research, biomechanics, material sciences, fluidics (PIV), and life sciences.
Melissa Larson
