2015 Automation Corporate Report Robotics
Corporate Profile 2015: Yaskawa America Inc.
EP Editorial Staff | December 17, 2015
Yaskawa is the leading global manufacturer of low and medium voltage AC inverter drives, AC servo systems, machine controllers, and industrial robots. Our standard products, as well as tailor-made solutions, are well known and have a high reputation for quality and reliability.
Be Capable of More with Yaskawa
As a machine builder or equipment user you have limited time, limited resources, and tight deadlines. You need a supplier that cannot only deliver the right products, services, and solutions, but can also deliver consistently and reliably. For 100 years, Yaskawa has been providing cutting-edge automation technology, operational excellence, and a breadth of engineering expertise to help customers solve their specific motion challenges.
  • Products that Perform:  With Yaskawa, you have access to solutions that provide real impact on your equipment effectiveness. You have the confidence that your machines will work as expected every time, and give you a competitive advantage in the market.
  • Operational Excellence:  Yaskawa empowers you to consistently deliver reliable equipment to your customers, and have that equipment continue to operate without unscheduled downtime.
  • Engineering Expertise:  Yaskawa works as an extension of your engineering staff to provide you with the time, resources, and confidence to create elegant, reliable automation.
Drives & Motion Products
Our broad product range of rotary, linear, and direct drive motors matched with digital SERVOPACKS (3W to 55kW) can be matched with our single or multi-axis machine controllers for a system with the best quality and reliability in the industry.  Our AC inverter drives cover every application need in the industrial plant, offering the greatest selection of size and performance available, with power ranges from fractional HP to 16,000 HP.
Robotics
With over 300,000 robots installed worldwide, Yaskawa is committed to a comprehensive, customer-centered approach in robotic solutions.  Our line of industrial robots increases efficiency, provides consistent quality, and boosts productivity to deliver outstanding ROI. The Yaskawa Robotic product portfolio ranges from 4 to15 axis industrial robots with load capacities of  2 to 800 kg to special machines, devices, and turnkey systems.
GR.YAI.05_blueYaskawa America Inc.
2121 Norman Drive South
Waukegan, IL
P: 800-YASKAWA or
847-887-7000
yaskawa.com
