Connector/Polyurethane Belting System
Gary Parr | June 29, 2016
Eagle SureConnect connector/polyurethane belting system is said to allow lines to be repaired and returned to service in approximately five minutes. The system uses a flexible connector and matching polyurethane belting. Two belt ends are joined together by a threaded connector to provide a strong, consistent connection. Welding is not needed. According to the company, the system has received rigorous flex fatigue, tensile strength, and elasticity testing to ensure performance in any standard welded-belt application.
Fenner Drives
Manheim, PA
fennerdrives.com
