Instrumentation Products
Flush-Tip Pressure Transmitter
Gary Parr | July 20, 2016
Model 386 pressure transmitter has a flush-tip zero cavity design said to eliminate the traditional measurement challenges of port clogging and removes installation torque effects on the output signal. The unit has a solid stainless-steel machined diaphragm and all-welded sealed housings. An isolated sensor reportedly eliminates the need for adjustments to the pressure transmitter after installation. Available in 13 standard ranges from 0 to 150 to 0 to 10k psig or psis, the unit can withstand as much as 1.5X proof pressure and 5X burst pressure. Additional ranges and models are available.
Viatran Corp.
Wheatfield, NY
viatran.com
Gary Parr
