Products
Hydraulic Fluid
Gary Parr | October 13, 2016
The Hydrex line is an addition to the company’s hydraulic fluids. Using highest quality base oils, the fluid is said to retain its fresh oil properties three times longer than other manufacturer’s fluids while delivering two times better wear protection for extended equipment life and reduced mechanical failures and maintenance. Hydrex AW is an anti-wear fluid for use in industry segments in which temperature variations are limited.
Petro-Canada
Calgary, Alberta
petro-canada.ca
Gary Parr
