Products Tools
Brake Lifting, Installation Tool
Gary Parr | June 23, 2017
The LBS 120 yaw brake lifting and installation tool uses a simple carriage assembly to position, raise, and lower brakes to minimize heavy lifting. For brake assemblies with a maximum width of 502 mm and a brake disc thickness of 40 mm, the tool uses a winch mechanism with a maximum lifting height of 2,000 mm. Once the lifting tool has been installed, the original brake can be released, allowing it to rest on a sliding carriage that is used to position the brake below the winch mechanism used to lower it to the floor. The process is reversed to install the new brake, after which the tool can be repositioned to work on the next brake.
Svendborg Brakes USA
Highlands Ranch, CO
svendborg-brakes.com
Gary Parr
