Bucket Elevator Drives
Gary Parr | June 22, 2017
Redesigned bucket elevator drives use two drive units for each power train. With the Flender gear drives as the main drive, the Siemens Simogear geared motors are used as auxiliary drives. The Simogear motors provide high energy efficiency using the shank pinion principle with the unit’s compact design due to an aluminum housing and integrated end plate. Flender gear units can be customized for user requirements.
Currax GmbH & Co.
Hamburg, Germany
currax.net
