Analysis Condition Monitoring Equipment Maintenance Pumps Reliability Vibration monitoring
What’s Your Noisy Pump Really Saying?
Maintenance Technology | July 12, 2017
Centrifugal pump and motor in power plantBy Eugene Vogel, Electrical Apparatus Service Association (EASA)
Everybody likes a quiet pump–it just does its job, leaves you alone, and doesn’t break down often. But a noisy pump raises concern. Although the noise is often attributed to cavitation, not every noisy pump is suffering from this problem. Failing bearings, flow turbulence, recirculation, and even a machine’s mechanical or electrical geometry can generate noise, any of which may be a more immediate problem than long-term damage from cavitation.
Cavitation erodes the suction eye of the impeller without affecting its other surfaces. Disassembly and inspection will confirm if significant cavitation is responsible for pump noise, but the first step is to rule out other potential causes with non-intrusive tests.
Rule out bearing noise.
To determine if the noise may be due to failing bearings, listen on the pump volute and bearing housing. An ultrasonic listening device is helpful, but a mechanic’s stethoscope will do. If the sound is louder on the volute than on the bearing housing, bearing noise can be eliminated as a source.
randmChange suction pressure.
Next, increase the suction pressure (head) if possible and listen for a decrease in the noise. If suction head can’t be increased, reduce it and listen for an increase in noise. Cavitation is directly related to suction head and flow, so changing either of these should cause cavitation noise to change accordingly.
Check for recirculation.
If suction head changes have little effect on the noise, the source may be recirculation resulting from a discharge flow restriction, perhaps due to a blockage or closed discharge valve. For closed systems without flow-rate instrumentation, verifying flow may not be easy. A portable flow meter attached to the outside of piping will provide accurate data, but such instruments can be expensive.
Another approach is to open a drain valve in the discharge line near the pump and allow flow to exit the system. If this reduces the noise at the pump, the flow through the system is very likely restricted, and recirculation is the source of the noise. Recirculation can damage pump impellers and volutes and subjects the pump to unnecessary vibration. Of course it’s also a waste of the energy consumed by the pump.
Determine if the noise is related to mechanical and electrical geometry.
If changes to neither the suction head nor discharge flow alter the noise characteristics of the pump, the sound is probably mechanical in nature. Mechanical sounds occur at specific frequencies related to the machine’s mechanical and electrical geometry. Vibration-analysis techniques can identify and characterize these sounds and their relationship to any mechanical forces.
The most common frequency of sound and vibration in centrifugal pumps is vane-pass frequency, which occurs at the multiple of the number of impeller vanes and the rotating speed. Technicians familiar with pumping machinery may well be able to audibly separate the vane pass and other mechanical sounds from the random noise of cavitation and recirculation.
In other words
Your noisy pump may be telling you something important. With a methodical approach and through the process of elimination, you can translate its language and avoid pump failure. MT
Eugene Vogel is a pump and vibration specialist at the Electrical Apparatus Service Association Inc. (EASA), St. Louis. EASA is an international trade association of more than 1,900 electromechanical sales and service firms in 62 countries that helps members keep up to date on materials, equipment, and state-of-the-art technology. For more information, visit easa.com.
