Mechanical Systems Products
Explosion-Proof Flow Monitor
Gary Parr | August 3, 2017
The Blancett B3100 series flow monitor is a flexible, reportedly easy-to-use digital signall-processing platform for flow-metering applications. Data logging and remote data access and programming are available without opening the enclosure. The monitor processes a frequency output from a flow meter and interprets the signal to calculate flow rate and total flow simultaneously with 16-point linearization of the flow curve (with interpolation) for improved accuracy. The unit features simplified K-factor and engineering unit configuration for volumetric or mass readings. The unit is explosion-proof for harsh surroundings in accordance with ATEX, IECEx, FM, and CSA c-us.
Badger Meter
Milwaukee
badgermeter.com
Gary Parr
