Remove Downtime Causes
Klaus M. Blache | June 1, 2023
Downtime, in simplest terms, is when assets are not available for use as needed.
This can be for unscheduled or planned downtime. When I assess factories or take plant tours and discuss challenges and opportunities, there are many reasons given for causes of asset downtime. Here are the 30 most common:
• Lack of preventive maintenance
• Too much early intervention/excessive maintenance
• Human error during maintenance
• Human error by operators
• Too much reactive maintenance
• Improper storage practices
• Poor crib management
• Lack of a reliability/proactive maintenance culture
• Mechanical-component wear
• Stopped to resolve quality issues
• Lack of effective planning and scheduling
• Software/IT system issues
• Power outage from internal infrastructure issues
• Power outage, lightning strike, and other weather or external reasons
• Outages (planned or unplanned) because of asset deterioration
• Never designed/installed correctly and has never produced at expectation
• Aging assets
• Inability to obtain replacement parts when needed
• Operating with less-experienced people due to high employee turnover
• Insufficient use of predictive technologies
• Use predictive technologies, but don’t do sufficient root cause analysis
• Maintenance that cannot be performed while assets are operating
• Investigations for safety/accident follow-up or continuous improvement
• Management decisions to operate longer/faster and postpone maintenance
• Limited number of employees who can maintain specific equipment
• Lack of clear and sufficiently detailed maintenance tasking instructions
• Performing maintenance, but not doing it according to instructions/best practices
• Poor cleaning practices
• Insufficient time to perform maintenance
• Lack of “design for reliability and maintainability”
If all you do is look at the initial downtime symptoms observed, the reasons fall into the categories as shown in Figure 1. Many of the items could be people or process, so those items were split in the tally.
I also grouped the 30 downtime reasons into four categories based on who controls them (Figure 2). The Engineering (Equipment & Other) category includes items such as outages, wear on mechanical components, aging assets, and safety investigations. Improved focus on the exact breakdown issues would, of course, depend on maturity of the current reliability and maintenance processes and the workforce readiness for change. More than 70% of companies still point to culture as the biggest roadblock to instilling a proactive mindset. Similarly, where plant-floor practices and culture enable an operator to get more involved in R&M, the benefits significantly decrease downtime.
Actionable items should be prioritized by cost and timeliness of implementation versus benefits. Then identify how improvement will be measured. Finally, discuss what leadership supporting behavior will be needed to instill the better practice and leading key performance indicators. As your culture and processes improve, more of the continuous-improvement initiatives can shift to the plant floor. EP
